Workspace Synchronisation
It would be nice if you could remove directories from the synchronization in the work area synchronization.
For example, templates.
Regards Gerd
1 Comment
dominik.gleinser
Hallo Gerd,
maybe I interpret your question not correctly, but if I do, there should be a possibility in the configuration of the workspace sync.
All Folders or files you define in the bottom window are not included in the check for workspace sync - the function should work faster after the definition. I also set the template path as default in the bottom window.
Hope this helps
Dominik
Technology Administrators
