Show only
Search instead for
maybe I interpret your question not correctly, but if I do, there should be a possibility in the configuration of the workspace sync.
All Folders or files you define in the bottom window are not included in the check for workspace sync - the function should work faster after the definition. I also set the template path as default in the bottom window.
