VAULT SETTING - PROPERTIES - CREATE A NEW ATTRIBUTE TO ENABLE COMMENT
This is a small idea but this might help the administrator and users.
Would it be possible to add an new attribute "COMMENT" to let the administrators to describe the attribute. moreover if this comment might be displayed in a kind of tooltip/infotip to help the user to know what the attribute represents.
Best regards
4 Comments
ihayesjr
@philippelandry4954
I moved this post from the Ideas board because you can create you own user-defined property in Vault to do this.
philippelandry4954
Hi Irvin,
I think that there is a misunderstanding.
I don't want to create a new property, I just wish to add a comment that describe the property itself that might be the "DESCRIPTION" of the CATEGORY or the LIFE CYCLE.
In fact we created a lot of UDP and some time the property name is not enough to let the users what to fill. So a short description (not a comment 😉) may help the user.
Sorry if I was not enough accurate.
best regards
Philippe
ihayesjr
@philippelandry4954
Thanks for the clarity.
I will move this back to the Ideas board.
Frodl
Hi Irvin,
that ist a very helpful idea.
We have many userdefined attributes / properties. Some of them are named with abbreviations because of the name will get to long or our client has defined them.
For a better understnding and easier use an explanation in a additional "comment" would be fine.
Best regards
Stephan
