With Vault 2026+ using .NET 8 (& the separated .NET Core version of 2025), there is no separate execution context for the add-in to run. So, if there is a NuGet package/assembly version conflict with the add-in and Vault or another add-in, it will cause an error. Below are some resources for how to do this manually within each add-in.
Could this be built into the standard 'IWebServiceExtension', 'IExplorerExtension', & 'IJobHandler' to prevent the need to do this manually?
Blog article on Vault add-in implementing AssemblyLoadContext:
https://tylerwarner.dev/assemblyloadcontext-for-vault-addins
Sample Vault add-in implementing AssemblyLoadContext:
https://github.com/tylerwarner33/autodesk-vault-assembly-load-context
Blog article on Vault add-in implementing AssemblyLoadContext via a NuGet that updates the IL code at runtime:
https://tylerwarner.dev/assemblyloadcontext-for-autodesk-addins-with-isolatorfody
Sample Vault add-in implementing AssemblyLoadContext via a NuGet that updates the IL code at runtime:
https://github.com/tylerwarner33/autodesk-vault-assembly-load-context-fody
Revit implementation discussion about internal implementation:
Accepted Inventor idea for the same internal implementation:
