Use AssemblyLoadContext Internally Within Inventor Add-Ins
With Inventor 2025+ using .NET 8, there is no separate execution context for the add-in to run. So, if there is a Nuget package/assembly version conflict with the add-in and Inventor or another add-in, it will cause an error. Below are some resources for how to do this manually within each add-in.
Could this be built into the standard ApplicationAddInServer to prevent the need from doing this manually?
Blog article on Inventor add-in implementing AssemblyLoadContext:
https://tylerwarner.dev/how-to-use-assemblyloadcontext-for-isolating-inventor-addin-dependencies
Sample Inventor add-in implementing AssemblyLoadContext:
https://github.com/tylerwarner33/autodesk-inventor-assembly-load-context
Revit implementation discussion about internal implementation:
https://feedback.autodesk.com/project/forum/thread.html?cap=cb0fd5af18bb49b791dfa3f5efc47a72&forid=%...
8 Comments
Yuming.Zeng
Hi @TylerWarner33 ,
Thank you for your idea. This was logged as INVGEN-69391.
We're working on the research.
Yuming
TylerWarner33
From what I hear, the attempt to do this in Revit was broken for 2026, but expected to be completed in 2027.
soonhui
I hope that AutoCAD will also implement the same useful feature, as per here
Yuming.Zeng
@TylerWarner33 @soonhui
You can give it a try with Inventor 2027 Beta 2 build. To load the addin in a separate Assembly Load Context, you can add below code into your .Addin file:
<UseInventorAssemblyContext >0</UseInventorAssemblyContext >
ChrisMitchell01
Status changed to: Accepted
You can apply for access to the Inventor Beta program using this link - https://Autode.sk/InventorBeta
TylerWarner33
Awesome! I will test it out, thanks @Yuming.Zeng & @ChrisMitchell01.
I just posted the same idea on the Vault Ideas forum here.
This may or may not already be in development.
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2027, and please have a try. Many thanks!
smilinger
Great! I hope this is also implemented for Vault.
