Currently (R2021) Vault Job Processor reports status ERROR on a Job, if it can't acquire a license.
This is essentially wrong - as it is the Job Processor with the Error - not the Job!
It also means the job is failed and cannot be picked up by other Job Processor - unless Admin Re-submit job.
As a License server with no License will quickly continue to next job, it will in no time send the entire remaining Queue to Error status, and leave a big tidying up Job for the poor Admin (= Me!).
In our setup will will probably need to run several Job Processor simultaneously, and one JP could loose the connection to a License server. The Job Processor with no License should instead attempt to pick up a License again 5 or 10 min. later and hopefully continue.
We would like the failed Job Processor to send a notification to Admin after 3 failed attempts to get a License, while the other JPs continue working through the Job Queue.
Regards
Uffe Bak
