Search Folder - Extended Search at Thin Client
User wants save extended searches at thin Client environment like Vault Browser.
Currently, users have to create a new search in the ThinClient after each new login.
The wish here is that advanced searches can be saved on a user-specific basis.
As well as that the administrator can publish advanced searches for the ThinClient
7 Comments
Uwe_Lindner
Requirement - Extended Search at ThinClient
Optional - Distributed Search in separate Column "ThinClient"
Das Speichern von begrenzten erweiterten Suchvorgängen wäre sehr hilfreich. Besonders bei größeren Datenbeständen ist ein dauerhaft gespeicherter Filter wünschenswert.
ihayesjr
@Uwe_Lindner
For the Thin Client, a Search can be saved as a browser bookmark.
Clicking the link will allow you to search again and modify the search.
Uwe_Lindner
Thank you we understand that we make saved favorites links!
ihayesjr
So everything you asked in the Idea post is already possible.
Uwe_Lindner
Thank you, we understand that we make a saved favorit as bookmark!
Robin_Kleinwort
I understand that a specific extended search can be saved as a browser bookmark. However, I would like to save the option only to search in a specific category, in my case "Drawing No.". Now I can only save via bookmark to search e.g. "Drawing No" is "pn-1785". But I want to have a quick and efficient way to search for any drawing no.
Why? We use the thin client on our shop floor. Drawings are not printed anymore, but workers open them directly in VAULT. However, when the worker uses the normal search and enters for example the drawing no "pn-1785" he gets several entries and needs to keep on searching himself or configure an extended search. If you need to do this 30 times a day, it starts to be annoying.
