Revit Interoperability - missing functionality
An Inventor assembly can contain Revit exports.
The Revit exports can be updated from the assembly using RMT or the simplification can be edited afterwards.
If the assembly is checked in, the Revit exports do not appear in either use or reuse. Which is a pity in principle.
Furthermore, the RVT files remain local in the working directory and are not offered for checking in when the main document is checked in.
Shouldn't the functionality of checking in Revit exports be covered by Revit interoperability?
Background:
The Revit files should be updated after a change in the Inventor model and then sent to the ACC as a new version via Vault.
Currently, the RVT files created as an export from Inventor have to be manually checked into Vault.
If a Revit export is updated, then you have to manually remember to check out the existing RVT file before performing the update. And then you have to check in again manually.
Is it wanted like that?
The Vault Browser in Inventor does not indicate Revit exports.
It would be helpful for users if the RVT files could also be checked in for Revit exports, as in the model browser.
How to see on Vault client side that Inventor model contains Revit export files?
For more Information see Support Case 20592761
1 Comment
marco.coelho
Is there any news about these Inventor/Vault limitations in checking the assembly by linking the RVT file in Revit Exports?
