Revit - Can't add new lines to Vault Options filter
Description
Can’t add new lines to the 'Add to Vault' list. When the filter list has focus and then pressing Enter to add a new line, it presses the OK button on the dialog instead.
Impact
Can’t add new filter extensions into the list.
Severity
High
Solution
When the filter list has focus, make pressing Enter add a new line.
6 Comments
ihayesjr
AdamPeter
Chad,
Users are able to add new lines of text.  Simple check the box and move to the last item on the list.  Add a space between that text and your new file extension.  In fact as long as you deliniate by space you can add as many as you like.  When finished click ok.  When you reopen the options dialog you will see the new extensions on the list.
ihayesjr
Status changed to: Accepted
Chad-Smith
Thanks for that reply Adam. From memory, I think I found out that I could also ALT/CTRL+ENTER to move to a new line.
The problem is that both of these options are not very obvious (discoverable) to the user.
It would be easier if we could just press ENTER without the closing the dialog.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
