PLot Manager: Batch Plotting squence follow Assembly Structure
background.
1. vault plot manager already have functionality to print all drawing related to file sheet, we can use to plot all file related to an assembly.
2. but there is no option to shorting by assembly structure
3. it'll consume a lot of man hour to shorting document follow assembly structure after printing. ( i.e. I've hundred drawing in main assy ).
Idea.
1. add additional feature to add all child document from an assembly.
2. short by assembly structure.
2 Comments
mill1806
We also spend a significant amount sorting drawings.  Our drawings need to be sorted by someone to facilitate planning and manufacturing workflow.  Sorting by part number only goes so far, and it doesn't always print them in order anyway.  We generate several print packages on a daily basis, and we're constantly trying to reduce the labor required to process an order and generate a print package.  Sorting prints is probably the most time consuming part of the entire process.  Being able to print following the assembly structure would help decrease the time to generate print packages and increase the productivity of individuals needing to generate them.
Hi @mill1806,
thanks for the vote.
exactly, we've the same problem to manual sort after batch plotting.
