PDF by checking in
PDF by checking in
We always want the latest PDF file of a drawing despite it is "released" or "work in progress".
Can there be a check box in the PDF settings "every time the file is checked in"?
1 Comment
Good Idea but it will maybe create a lot for errors in the Vault Queue, because the Pdf Create will not be triggered by State Change!
Furthermore if the job-server is used for it it will be constantly in use, and you never know when our Pdf File is ready.
You need than manual check if the file is handled and out of the Queue without error or non tip versions.
If the mechanism is used form Inventor Like the Dwf file Creation you will have a Pdf that is maybe based on older or newer file versions and not the latest release Information.
