Part update
Part update
Say I have 20 assemblies, each assembly has a specific part in common. That specific part I would like to update once and have Vault automatically do the other 19. How can this be done?
3 Comments
olearya
Hi There,
Thanks for posting your idea, at present we do not open and update references in locations where a file is used as this may have significant performance impact, cause errors where parent files are locked and introduce unintended issues in older models.
Note that we do reference latest on next open and edit of a file, which is where we do the update, as you require it, not automatically.  This is perhaps something that could be revisited in the future in certain circumstances.
(Worse case option is to select where used for file and manually open and save all files).
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
