Option need to set default project file to open files
When there are multiple project files available in vault it prompts each time to select the right one when I try to open a file.
Instead if I have an option to set my default project file to open the files it would be helpful.
Existing option(Tools--> options-->Inventor Project file) to define default project file didn't help.
Even in Vault settings the desired project file was defined as the Default Inventor Project file.
Sathish kannan V
2 Comments
bjoho
This is a very annoying behavior when Open from Vault client.
Please make the setting in Options also apply to the Open command.
Best regards
Björn Holmgren
boris_vaintroub
It looks like a bug.
Enforce single project file doesn't work.
Default project file doesn't work
