If I try to move a folder structure where one or more files in the sub structure are checked out, the whole process stops with a warning and nothing is moved. It would be very helpful if as much as possible were moved and only the checked out files were kept in the original source structure. This should of course only be done after a warning where you get to choose cancel or continue.
Ideally/alternatively it should be possible to move checked out files. Vault should still know where to put the files when they are checked in again even if in a different folder than were checked out from.
