Job Queue limited to 1000 Jobs
a possibility to enlarge the limited 1000 Jobs (e.g. as for search results) would be great!
We have a lot of important standard-jobs (e.g. ERP-Interface, drawing Export for purchsing department),
that I can not see anymore (wheter if they are in the Queue, nor if the resulted with error),
we cannot see anymore if we e.g. generate thousands of dwf simultaneously.
Or the filterfunktion works for the whole Queue entries not only for the shown 1000.
12 Comments
Good idea for Admins very useful, espacially wehn ERP or other Jobs are used.
gilsdorf_e
I'm curious:
In the past I several times suspected perfomance in Vault suffered dramatically when the number of jobs in the queue exceeded like 200 entries. As you have this scenario frequently: Do you think the same way or is it just me / our vault?
Our experience is that you have this issue when the SQL and IIS runs under heavy load.
So especially if the Jobserver and Vault Server installed at the same machine.
We have often the case that the jobs in queue exceed the number of 1000 elements.
Regards
There's not even a filter we can apply (to then search by type of job submitted, or type of error, etc), and when trying to fudge with the useless "Group by Box" and "Group by this Field" functions I ended up having to reset the view for the window...
Senthil_Kumar
A question to all of you since we are looking into this issue
- What is the estimate maximum number of jobs in your queue at a time?
This will help us to set the maximum limit - if needed. Thanks
Hi!
If we do a mass job (export pdf of drawings, ... ) we do packages of 10.000 jobs in the Queue.
If we could handle more (better filtering/viewing of jobs), we would do more.
Hi!
If we do a mass job (export pdf of drawings, … ) we do packages of 10.000 jobs in the Queue.
Senthil_Kumar
@MarkusGreifeneder3360  Thanks. Another question. Do you want to see all the jobs in one go?
Also, Even today you can filter them. But only on the 1000 jobs.
Yes, I can filter now. But the filter only filters the "first" 1000 files.
If the filter could work on all the existing jobs this would be a good improvement.
And it would also be great to be possible to see all the jobs (equal to ordinary Vault-File-Search, where i see 1000 searchresults, but I can say "More" until I see all)
limin.chung
Some possible solutions for this idea are currently under discussion on the NDA based Vault Feedback/Beta forums. If you would like to contribute/validate then please apply for access using this link:
Limin
Senthil_Kumar
Status changed to: Accepted
Senthil_Kumar
This is implemented in Vault 2021. For more info on Vault 2021 What's new please refer this page - What's New in Vault 2021
