When I change -state- of a large assy with a lot of Documents the -Job Queue- is very busy.
By changing -state- I can see in a very clean way the input of change.
Then the Job Queue is automaticly started.
But I never see if the result of the Job Queue is 100%
The errors given by the Job Queue is not very helpfull.
I have always to check -Job Queue-, check -Secondary Documents-, check -Item-, check -Item-Partlist. because of the job queue.
Can you built a Check to check the results of Job Queue.
