Hello VAULT team,
at the moment it is possible to customize the output file names of PDF files created with the Job Processor by modifying the Job Processor configuration file JobProcessor.exe.config.
The naming convention defined in the config file is valid for all files in the vault.
(see picture "VAULT-1" and "VAULT-3")
However, in different projects we need different definitions for the naming conventions for the created PDF files.
It would therefore be important to be able to define multiple name definitions in the config file. The application of the appropriate naming convention should be based on the file category of the file from which the PDF is to be created.
(see picture VAULT-2)
For each project, we create a project-specific file category and use it to assign the appropriate life cycle and revision scheme to the files.
Using this project-specific file category, the job processor could recognize which naming convention it should use to create the PDF file.
It would be great if these configuration options were added quickly.
Thanl you.
