Improve Copy Design
Improve Copy Design
Vault copy design is an important function for companies increasingly committed to modular design and reuse of standard manufacturing parts. Copy design is an important function in this. With copy design, the engineer chooses which parts to reuse and which parts to copy.
What often goes wrong is that the engineer unconsciously makes copies of parts that should actually be reused because they are standard components.
Request for improvement; can Vault Copy Design be given a Configuration Rule in which it can be preset which file categories are reused by default and which categories are copied by default? That way the engineer gets a recommendation that can be adopted. This prevents uncontrolled copying of std parts.
See Image for suggested idea.
Martijn van Giels
Arkance
8 Comments
RajSchmidt
Excellent! Right now you can only filter out components in library paths. It would be nice if we a bit more flexibility here.
bas.claassen
The current functionality that you can filter library parts is ok for Vault Basic. Vault Professional needs an extended feature.
BDCollett
This would be excellent. Filter by Category would make this process a lot faster.
uffe-bak
I would also like to second this request.
It would be hugely beneficial if Rules for Copy, Reuse and Replace could be created from criteria in Vault Properties
Exactly what we need!
uffe-bak
Great suggestion and aligned with our own request forwarded to Autodesk Vault Product Management
mathias.willen
This feature is requested in almost all Vault projects. Requested and expected, also.
aritchey
Observer
I agree this functionality would be awesome.
We currently use libraries to restrict files from copy design, but it is a pain when you need to update standards and library files.
