Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Improve Copy Design
Improve Copy Design
Vault copy design is an important function for companies increasingly committed to modular design and reuse of standard manufacturing parts. Copy design is an important function in this. With copy design, the engineer chooses which parts to reuse and which parts to copy.
What often goes wrong is that the engineer unconsciously makes copies of parts that should actually be reused because they are standard components.
Request for improvement; can Vault Copy Design be given a Configuration Rule in which it can be preset which file categories are reused by default and which categories are copied by default? That way the engineer gets a recommendation that can be adopted. This prevents uncontrolled copying of std parts.
See Image for suggested idea.
Martijn van Giels
Arkance
5 Comments
RajSchmidt
Excellent! Right now you can only filter out components in library paths. It would be nice if we a bit more flexibility here.
bas.claassen
The current functionality that you can filter library parts is ok for Vault Basic. Vault Professional needs an extended feature.
BDCollett
This would be excellent. Filter by Category would make this process a lot faster.
Exactly what we need!
uffe-bak
Great suggestion and aligned with our own request forwarded to Autodesk Vault Product Management
