Have Vault Backup Checks Happen Before Validation
When a vault is backed up from ADMS it will perform the database validation prior to checking things like if the path provided is accessible or if the Autodesk user has write permissions to the target folder. (There is also not a check if there is enough disk space available for the backup to succeed properly.)
This can cause slowdowns as the validation is an extended process and can take an extended time before the issue becomes apparent.
3 Comments
ihayesjr
@battoZLPGX
Thank you for posting the idea. When you say "export" are you talking about performing a backup?
battoZLPGX
Yes, sorry I did mean to say backup. Thank you for catching that.
Yes! This will be such a timesaver
Also add a check on IIS recycle times, my file validation was almost ready and then got a reset (after 23 hours)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/File-store-validat...
