Grid conditional formatting, calculated property fields and totals
I would like to post an idea to extend the grid columns with conditional formatting rules on properties.
With this you can highlight properties if they contain/are equal/not equal/etc. to a specific value.
Users can create a more visual status of their grid.
To extra extend this functionality it would be nice to create calculated property rules/property formulas.
So the same described as above, a property value will be created based on other property values.
On the bottom it would be useful to add grid totals, where users automatically see total sums, averages or counts.
11 Comments
ihayesjr
@bas.claassen
Thank you for posting the idea.
On the topic of "..highlight properties if they contain/are equal/not equal/etc. to a specific value."
You can set that a property must have a specific value in the User Defined Property settings. Then when the property value doesn't match, a Red icon appears next to the property and in the main file grid, an icon appears showing that there is a property compliance error. Have you tried this?
bas.claassen
Hi @ihayesjr
Thanks for your reply. I'm aware of this functionality, there are some options for required values for property values. But these are not based on custom conditional rules so you can't control the behavior of the highlighting.
ihayesjr
@bas.claassen
Can you provide an example of a custom condition you would create if this feature was available?
Also, are you aware that you can build custom conditions in Vault Data Standard and prevent a file from being checked in if a property doesn't have the correct value based on your conditions?
bas.claassen
@ihayesjr,
I’m aware that Data Standard can do this.
An example:
Due date for review/release file or item; due date for closing change order: If this date is overdue, I would like to see in the grid that this date will highlight in red. If this date is in the same week as this week, then it’s highlighted in orange.
Right now, you can create this with saved searches. But this will not give you a dashboard, you have to click to these saved searches to get an overview.
ihayesjr
Ok, would a dashboard with this information be better than having this modification to properties?
bas.claassen
@ihayesjr Why not both.
ihayesjr
Performance cost on the client would be a concern. The more information that is calculated on the fly, the more time it takes to populate the grid and display what is needed.
bas.claassen
Maybe it is better to create option for distributed searches & views. A dashboard is also a possible way.
ihayesjr
@bas.claassen
You can already distribute searches and views.
Vault 2024 Help | Administration Enhancements | Autodesk
bas.claassen
@ihayesjr I know. But to have these extra options for conditional formatting on (distributed) searches and views. So the user decides on specific searches and views to have these extra calculations.
ihayesjr
Status changed to: Archived
