Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Folder Focus changes to destination folder During Move Operation
When moving files, focus shifts to the destination folder. I would like this to work more similar to the way Windows explorer works. This also applies when RMB dragging to create links in destination folders.
A lot of time is lost by users having to continually browse back to the previous location and performing a search to get back to whatever results they were previously displaying.
27 Comments
When moving a file(s) to another folder. Don't change the view to the destination folder!!!!! I want to keep viewing the files in the folder that I was working in. Windows Explorer does NOT behave in that manner for a reason. (Reason... people would be angry)
ihayesjr
Senthil_Kumar
@cmcconnell
Just curious on this statement.
We have a Move Back Button for this purpose. Was it not useful here?
I have not seen this Move Back Button? Where is it?
cmcconnell
There is a blue arrow up in the menu to move back...
cmcconnell
It helps, but it is only half a solution. If I am working from search results, I have to rerun the search.
I am probably working with a 100:1 ratio of wanting to be in the destination folder vs. The source folder when I move files or create shortcuts in Vault.
Senthil_Kumar
Thanks Cory for the reply and information. We will see how to move forward with this request. Thanks again.
It would be nice if in Vault when moving files you were not taken to the folder in which the files are being moved to but instead could stay on the screen you are moving from. This would be especially helpful in searches. Also it would be nice if you could move multiple files from different paths at the same time.
Tags (3)
johannes.bauer
Autodesk Support
you could use powershell to move the folders using documentservice.movefolder command
cmcconnell
I just received an email that you were archiving this idea Senthil. Does that mean it is no longer under review? And, as a result will not be implemented?
Senthil_Kumar
@cmcconnell Cory,
This idea is still "Under Review" state.
limin.chung
Some possible solutions for this idea are currently under discussion on the NDA based Vault Feedback/Beta forums. If you would like to contribute/validate then please apply for access using this link:
Limin
ThomasRambach
@limin.chung this change would personally save me quite a bit of time in a week. It would be good for this to make it into a release soon. An option to run on or off would be best.
jimmydieck
Has this been resolved? I would like to move files and stay in the same folder I moved the files from. Right now I have a "Staging Folder" in order to sort files and it takes a lot of time to go back to the original folder I'm moving files from.
esimers
please implement this ASAP!! why is this even a thing?  Since when do you want to flop to the destination folder...I'm not done, I'm still searching...I'm still moving... Get this one implemented in a hot fix ASAP!  I've spent hours moving files, mostly going back and RE-searching!!
When I move a file in Vault, the program will open the destination folder. I would like to have the program keep me this the source folder. I can other requests for the same feature, please update this soon.
Staying in current folder when moving files to different folder in Vault | Vault Products 2023 | Aut...
Tags (1)
ihayesjr
mgrenier1
Yup, this needs to happen.
DavidWarta
Also agree best to have a toggle in the options menu.
For example:
File/Folder move, Go to destination folder.
This should be turned off by default.
ihayesjr
Status changed to: Accepted
