Filename Change support
We are Autodesk Inventor Users Group Japan.
We are the activities that convey to Autodesk the needs of users in Japan.
We post #3 strong demand from users in Japan last year, we have received.
When I change the file name in the Vault, After running the "update from the Vault" to a file on the local, I want to remove  file the old file name from the local automatically.
The rules of the house, we are using  the file name of the prototype for the trial at the time, and the file name of the unit number set when the official distribution, but if we change the file name in the Vault, because the old files may remain on the local PC , there is confusion.
When we change the file name in the Vault, we must remove one by one the old local file.
It is very helpless If we forget to delete, such as we accidentally delete or to the desired file.
Thank you.
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
