File Number Generator \\ Make components: change Pre-defind list selection in mass
In inventor, If you are using a per-defined list in your file number generator, there is no way to select a group of solids and change the drop down for all of the selected items. this is fine if you are only dealing with 3 or 4 solids. But when you may have to deal with hundreds of solids in an export it becomes time consuming.
There should be some sort of way to ctrl+click and/or shift+click a set of solids and change all the drop down menus at once.
