Greetings.
Expected result:
Drawing should inherit filename from its main model (usually 1st view), regardless of the selection in Copy Design.
Current result:
If we have several models on the drawing, drawing will inherit the filename from the first selected model in Copy Desing, which causes wrong numbering between main model and its drawing.
See the attached images. Arrow indicates selecting order.
1 - Original structure --> How it looks like before copying.
2 - Correct copying --> If we select models from top to bottom, numbering of the drawing is OK.
3 - Incorrect copying --> If we select models from bottom to top, numbering of the drawing is NOT OK.
Best regards,
Rene Repina
