Why isn't the current path/folder the default value for "Copy Design From"? In my opinion it certainly should be. We could at least be given the option to set this behaviour under program options, or just a check box to the left of the path field.
To be able to set a default path for the target path would also be convenient, as the path for this (at least in my case) almost always is a subfolder of a standard path like "$/Designs/Products/[year]/[target subfolder]" or similar.
In many ways Vault also works like the ContentCenter in Inventor in the sense that you have your own standard components that you frequently use, so another thing that would be convenient is to be able to set the default copy/reuse behaviour of each component in the design, both in each individual part/assembly AND for all parts/assemblies under a specific folder that you define yourself (like "$/Designs/Standard components/[manufacturer]/").
The default copy/reuse behaviour could even be given the option to be ruled by each components BOMstructure (If the component is "Purchased" the default is "reuse" otherwise the default is "copy").
