comparison view to local working folder / multiple file checkout
I've found on multiple ocasions that co-workers forgot to check in new files, causing them to be non-existant in the vault. It would therefor be useful if it would be possible to do a comparison between the current vault directory that is displayed and the corresponding local working directory.
another suggestion:
in a previous version it was still possible to chek out an entire folder. As file numbers can grow large, having to select each one by ticking the box now is extremely time consuming. (Or am i overlooking an option somewhere?)
It would be good to have this functionality once again. In relation to the previous idea, this check-out entire folder option can greatly facilitate local workspace maintenance as you can also perform an undo-chekcout on all files and remove all local working copies, leaving the non-checked in files on your system, which can then be sorted out easily.
Cheers,
Misha
4 Comments
ihayesjr
ryan
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
