I've found on multiple ocasions that co-workers forgot to check in new files, causing them to be non-existant in the vault. It would therefor be useful if it would be possible to do a comparison between the current vault directory that is displayed and the corresponding local working directory.
another suggestion:
in a previous version it was still possible to chek out an entire folder. As file numbers can grow large, having to select each one by ticking the box now is extremely time consuming. (Or am i overlooking an option somewhere?)
It would be good to have this functionality once again. In relation to the previous idea, this check-out entire folder option can greatly facilitate local workspace maintenance as you can also perform an undo-chekcout on all files and remove all local working copies, leaving the non-checked in files on your system, which can then be sorted out easily.
Cheers,
Misha
