Client-Side Status Codes
This is by far the most common HTTP status code you can get. It indicates that the URL you used in your request doesn’t exist on the API server, or origin server. While this is a 4XX error, which usually means something on the client-side is wrong, this can also indicate a server problem. Sometimes API URL paths change after a version update, but sometimes they change because something on the server went wrong.
1 Comment
ihayesjr
