Check if Server is locally reachable when using vault gateway
When you often swich between Office and out of Office using Vault, I always have to change the Vault Server Name (Local Name/Gatewayname) in the Login Dialogs.
My Idea is, that you are able to save the Servername in the Gateway Config and if I use the Gateway Name that the login is automatically check if the local Server is available and use this if available and use Gateway if not.
So it is possible to use "Logon automatically" and don't care which Name to use.
