If you do a change in your property mapping, e.g. add a property mapped to an item, then via Assign/Update Item you have no chance to get these changings into your item.
Because first you have to add the property manually to the item, then you get via Update/Assign Item the new value of the document into your item.
Question:
Why does Assign / Update Item not create the additional property in an existing item?
We have 166.962 items at this time.
How can we proceed without clicking each single item and add a property?
We all know, by the time we have to do any changings in the configuration.
It will be very helpful to give changings in the property mapping the full function via Update/Assign Item, like it is in a new item.
