Gang...
We have a bunch of time wrapped up in items which had properties mapped to the the item after the item was birthed. As our Vault matured, we added some properties to the item which weren't there at the time the item was created in Vault. I imagine every user of Vault has had this happen where as they grow with Vault, they add more and more properties.
Currently, the procedure is really convoluted and time consuming to get these newer properties to show up and map to the item. Even thought they are mapped in the Behaviors under Vault Settings.
If the item was not being revised...I can live with the property not being there. But, if you are revising the item, you shouldn't have to turn the properties on. If the property is currently being mapped, then the property should show up on the item.
This video demonstrates the task to get these items fixed...
http://autode.sk/2ehOT1Q
Thanks in advance,
Steve H.
