Change Orders - When doing a SAVE, records scroll back to top of list.
Ran into an issue on VP2016 with change orders, when you save, it scrolls clear back to the top of the records list. This functionality was like this prior to VP2013/14 and was fixed...now it's back again with 2016.
The records need to stay where you are at and not go to top of list when a save is executed.
Here's a video showing the issue....
http://autode.sk/1XGKHaC
7 Comments
Andy.Spivey
Just to add a comment - appears if you remove the column sort, re-open the change order to edit, the grid does not scroll / return to top after a save.
steveh3
Hello Andy...
Not sure what you mean when you sau "remove column sort"? I think you always have to pick a column. No way to turn sorting off in a change order.
Andy.Spivey
Hi Steve,
I added a comment / video in the forum post.
When editing the ECO, from the records tab, ensure that no columns are being sorted (ascending / decending order).  Should be able to righ-click click a column header and remove the sort option.
steveh3
Not sure that I am getting same result.
Here's what I am seeing...
http://autode.sk/1M2RWCK
Also...link to discussion group....
http://forums.autodesk.com/t5/vault-general-discussion/vp-2016-change-orders-scroll-to-top-upon-save...
Andy.Spivey
I see...  Workaround does not really help unless you can order the records to be able to find them quickly.  I will move any further thoughts to the discussion group thread.
-Andy
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
