API Control Command visibilty options
I work with several document management systems and they all very greatly.
One of the biggest issues I have with the Autodesk vault is the ability to control the available commands based on the user or the selected objects.
There should be a call raised in the extensions when ever a right click is initialized that the extension can then review
  1. Who the user is
  2. User Roles
  3. Object Permissions
Depending on reviewing this information have the ability to modify the command visibility.
  1. Enabled
  2. Disabled
  3. Hidden
Especially in a situation where I am currently working on a project that has 12 different commands but require different roles for the commands to execute and also require things such as the editable status of the file.
Rather than allowing the user to try and function and then cancel it would make a lot more sense to not even show or disable commands based on requirements.
Bruce
2 Comments
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
