Ability to set default display order of all lists
It is extremely annoying that for many things (properties, file categories, groups, etc) the default display order appears to be order of creation.  In situations like file category, you don't even always have the option of reordering the values in the list.  In others, like groups, you end up always sorting them alphabetically to start with.
Being able to manipulate the display order of lists would make administration and use faster.
7 Comments
ihayesjr
Status changed to: Archived
Display order can be set by clicking the column and it will be the sort order. Since each list is different, you will have to set each separately.
This is absolutely NOT solved. The idea is for DEFAULT sort order.  Having to sort the lists every single time I got into a dialog because they are in an order that doesn't make sense IS the issue.
I will resubmit this if there isn't any response to this.
This is not solved.
This is a resubmission of an idea that was closed as "Solution Provided" when in no way was there any solution provided.
Please do not mark it as duplicate unless you will change the previous idea back to new.
Being able to manipulate the display order of lists permanently would make administration and use faster.
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
