Vault Report
Vault Report
tschaeferZNBXX
Advisor Advisor
Vault Report
tschaeferZNBXX
Does anyone have a simple report that will give me the File Name and Revision level?
I do not want to see the thumbnails which come with the out of the box Vault reports.  I need to be able to export this to Excel as well.
The report will have approximately 200,000 files so any help would be great!
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
mflayler
We have some report tools that will do this, but they are a cost product.  Out of the box, I don't know an easy way to do it.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Thomas_Helm
is the File Table report not good enough? It includes the filename and revision. After you have generated the report you can export the results to Excel.
Cheers
TH
mflayler
No, I don't think for 200,000 files it would be viable, maybe 200-2000.
Thomas_Helm
Understood. In this case I guess you should use SQL query to get out the data directly from Vault. There is a view dbo.vw_file which contains more or less all important data. But be careful when you create your query to set the right conditions. Otherwise you can slow down your production DB if the query is not written in the right way...
TH
You could do a search and then "Print" that list
Use something like provider is "Inventor" and Revision is not empty
Alternatively you can edit the report RDLC file if you download Visual Studio 2008 with
Yes, that's correct, 2008
Here's the Autodesk articles I followed
http://images.autodesk.com/adsk/files/report_template_authoring.pdf
http://adndevblog.typepad.com/manufacturing/2012/07/customize-the-vault-report.html
