How to bring default iProperty into Vault Properties
pkrogSVW3G
pkrogSVW3G
I'm trying to make the vault description pull from the description field in Iproperties from Inventor 2023. The description fields are mapped to each other and should be writing either way (which is my ideal).
pkrogSVW3G_0-1750701623246.pngpkrogSVW3G_1-1750701627143.pngpkrogSVW3G_2-1750701630856.png
Can someone identify what is being done incorrectly here? I feel like it is something very simple, but I can't find the issue from the help articles or existing forum posts.
AnisNatashaDBT
hi @pkrogSVW3G
here's my configuration. with this i could change/update Description field either in Vault or Inventor iProperties and it will match. but i believe our set up are similar at this level.
can you try to back track the file association? i have Description properties enabled for files in Base, Engineering and Standard categories.
Configure Categories > Engineering
Each file types are assigned to category by Assignment Rules
pkrogSVW3G
Anis,
Thanks! turns out having the subcategories checked is a requirement; I was treating it as if the subcategories of the file type were automatically included if the upper level was selected, but that is not the case.
