Does check out refresh the file in the working folder?
SharkDesign
Mentor Mentor
SharkDesign
I found the main Autodesk article on this but it wasn't very clear.
If I check out a file, does it download the most recent version of the file and replace it in my working folder, or is it possible to check it out but be working on a version that is different from the most recent in vault?
I always use Get to replace the files on my local drive, but a colleague has been using checkout to get fresh copies and I wasn't sure if this was a safe way of doing it?
  Inventor Certified Professional
bradeneuropeArthur
It depends on several things.
What version of the file you get in relationship with the selected file.
if you have already files open in any other application than the files are get different.
and if you use the latest released version in the files related otherwise the one that is the last checked out wins.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
SharkDesign
Sorry I don't understand any of that.
For clarification though:
I have an assembly open in Inventor.
I right click the vault add-in and choose to checkout all files.
Will that replace all the files in my working folder with the current version from vault, or will it purely check them out to stop other people working on them and he will continue to see the local file from the working directory?
My colleague wants all files in Inventor to be the most current version and this is what he is using the check out process for.
I personally use 'get' because I don't believe you should check things out that you are not working on.
JamesMcMullen
If I am understanding what your co-worker is wanting, they can always set their "check-out" options to get the latest.  Here is an image describing the area they need to update:
James McMullen
Principal SQA Eng.
SharkDesign
Thanks, I will check they have this.
I'm assuming that's off by default.
And if it's off they could be editing an old version?
SharkDesign
If I tick the box under 'dialog suppression,' does that mean that it won't show the dialogue?
It's really confusing me the way it's laid out.
bradeneuropeArthur
That is correct!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
