Cannot install: This computer does not meet the minimum requirements
daniel_kuna
Message 1 of 16
daniel_kuna
Has anyone had this problem with installing vault client 2025.1?
These autodesk links below don't work. Uninstalling all products and cleaning the registry from autodesk entries doesn't work either.
And what is strange? that before 9.10.2025 everything worked
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cannot-install-Thi...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-install-...
https://help.autodesk.com/view/VAULT/2025/ENU/?guid=GUID-20DE42EB-F108-4999-8694-65AD12C15F66
Replies (15)
Message 2 of 16
ihayesjr
Are you trying to install the full client with the update, or the update only?
If you are trying to install the update only, how did you install the original client? Install now, download or deployment image?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 16
daniel_kuna
I'm trying to install the entire client with the update, not just the update. I get errors both with the web install and with the downloaded client. And the interesting thing is that the vault client 2024 installs normally.
Daniel
Message 4 of 16
ihayesjr
Download Vault 2025 without the update and install it. Do not use the Web installer or the deployment option.
This should allow you to install the client.
After that is installed, download the update and install it.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 16
daniel_kuna
Here you go - installation from a clean image without updates. It seems that Autodesk should take this problem seriously, no one can help, even support has not managed to solve the problem. Solutions are published that do not help at all, this is a terrible approach.
As I wrote earlier, I clicked through all the suggestions published on the Autodesk website - nothing helps.
Send some data from the logs ?
Message 6 of 16
ihayesjr
Did you create a product support case?
Irvin Hayes Jr
Autodesk, Inc.
Message 7 of 16
sikandar_ilyas
Hi @daniel_kuna ,
Please use the article below to collect logs from the your machine and send them across for further debugging.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Use-the-Log...
Regards
Sikandar
Message 8 of 16
daniel_kuna
35 Mb - should I attach it here? I made a case, but the consultations were quite chaotic.
Daniel
Message 9 of 16
sikandar_ilyas
Hi @daniel_kuna , yes please attach the log files here.
I assume it should be of format ODIS-Info_<timestamp>.zip
Regards
Sikandar
Message 10 of 16
daniel_kuna
https://autode.sk/48rfPrk
Daniel
Message 11 of 16
sikandar_ilyas
Hi @daniel_kuna ,
I checked the logs shared from your side and it seems Valut client installation was attempted before as well but it may not be removed from the system completely and now causing concern in current installation.
Can you please check if the subkey "62A625FC460301000000209E05916B82" exist under registry key "Computer\HKEY_CLASSES_ROOT\Installer\Products" on the machine where current installation is tried?
Regards
Sikandar
Message 12 of 16
daniel_kuna
Yes, there is such a key, it has directories but everything is empty. I deleted it but the installation error is still there.
I already mentioned that I deleted all autodesk products and cleaned the registry using MicrosoftProgram_Install_and_Uninstall.meta
Message 13 of 16
daniel_kuna
ok, it worked, I deleted all four occurrences of this key in the entire registry, not only in Computer\HKEY_CLASSES_ROOT\Installer\Products
and I managed to install a clean install without update 2025.1
Thanks for the tip sikandar_ilyas
Daniel Kuna
Message 14 of 16
sikandar_ilyas
Thanks @daniel_kuna for confirmation that you can install now. If no other concerns, please help close the case by accepting the solution.
Regards
Sikandar
Message 15 of 16
carstenandersen
Sorry for hijacking the thread here:
Could there be a similar key needing deletion for installing Vault Pro 2024 Client (Build 29.3.71.0)?
I get a similar message trying to install the client on one computer from our deployment server. The other 108 installs, than I've done the last month, ran smooth.
But this one computer is causing me problems. Specs are well and beyond requirements.
Br.
Carsten
Message 16 of 16
Ole_Dahl
Very helpful! We experienced the same issue right now, and was able to solve the issue immediately, thanks to your post.
