Upload Design Data to Vault
noakes_eng
noakes_eng
I have Vault setup, maybe not correctly but it works and I would like my design date and templates there. How is this done, have tried dragging the files into vault but as there are iam and ipt this fails.
And help is greatly appreciated.
Oliver
arkad_s
Autodesk Support
Autodesk Support
This might be helpful for you:
Putting Design Data and Templates in Vault 2024
Arkadiusz Sukta
Sr. Technical Support Specialist
Customer Technical Success
noakes_eng
@arkad_s  @Thank you I have read this post, and didn't really understand it. Where are the settings for restricting file types to be uploaded to Vault. I have already tried the drag and drop technique
arkad_s
Autodesk Support
Autodesk Support
Settings to block/unblock drag&drop method for CAD files is under Vault Settings:
Link to product help as reference:
Manage File Type Restrictions | Vault 2026
If you plan to use that way make sure to bring settings back after you upload Design Data (to avoid uploading other CAD files this way - drag&drop  doesn't maintain relationships, property extraction etc.)
Also alternative method to put your Design Data & Templates into Vault would be using Check in Project function, as mentioned below:
Check in Project is also mentioned here:
How to get the Inventor Design Data folder checked into Vault
I hope this helps.
Arkadiusz Sukta
noakes_eng
@arkad_s  Thank you very much for the help, greatly appreciated all the uploaded and new folder paths added to the project file.
Kind regards,
Oliver Noakes
