We want to create a test environment for a migration of a Vault.
The filestore is 2,2Tb and the SQL is 78Gb.
So for the SQL they don't use the express version, it is the enterprise version.
The current version is Vault Pro 2022, the upgrade will be Vault Pro 2026.
As for the SQL server, they have a seperate server where it is running on.
For the test vault there will be a new server for the filestore, on where i will install Vault and then restore the backup.
But for the SQL, do we need a new server with a new instance?
Or is it possible to run that at the current SQL server, can we make a new instance on that?
I believe that the instance needs a specific name? (and that name is already in use?)
Or can we give the instance any other name?
