Cannot edit properties in Vault Basic 2021
Message 1 of 24
Hi!
I cannot longer edit properties (ctrl+E) in Vault basic. This used to work fine before. Now i run 2021.1 and i don't really know if the problem started with the latest version...
I can go to Edit properties and then i get the window up. I fill in my changes and click OK. Then i get the report which says: "successfully updated" but then when i close the window nothing has been updated on my file.
Anyone know about this problem?
Replies (23)
Message 2 of 24
gandhey
Thank you for reporting the issue. I can see this issue with 2021.1 Vault update.
Dev team will take a look at this.
regards,
Yogeshwar
(Vault team)
Message 3 of 24
Hi!
When can I expect a solution for this?
Message 4 of 24
I also have this issue and it is infuriating!
What is the solution please?
Message 5 of 24
bradeneuropeArthur
Are you talking about editing:
  1. Vault properties in the Vault
  2. of about Inventor I-properties in the Vault?
If  the case is 2 then take a look at the mapping of the properties!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 6 of 24
As the description by the previous post.
It is a known issue with the update.
Message 7 of 24
bradeneuropeArthur
Sorry but for my understanding I need t know what properties you mean!
This is not clear for me.
  2. or about Inventor I-properties in the Vault, via property-mapping?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 24
I want to change the Inventor properties from Vault, like part number, revision, title, description etc etc. I don't know if that is Vault properties or Inventor properties and I do not know what you mean with mapping the properties. I never had any problems before.
Message 9 of 24
bradeneuropeArthur
If you want to change the inventor properties in Vault than there must be a mapping in Vault! (This is a link between them this is called mapping).
If you change is "Part number" what happens
  • Is the change visible in Vault
  • Is the change visible in the file in Inventor
Could you test that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 24
OK, thanks.
1. I tested create a part and checked it into Vault. Closed the partfile and removed working copy.
2. CTRL+E in Vault and changed the Partnumber. The dialog said "Succesfully updated"
3. The change of partnumber is not  visible in Vault neither in Inventor..
Message 11 of 24
bradeneuropeArthur
Next step:
  1. create a file in inventor
  2. fill in the property
  3. take a look in  Vault if the property is displayed correctly
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 24
OK, i tried this right now.
All the properties i filled is showing correctly in Vault.
Message 13 of 24
@bradeneuropeArthur  I did try this... I Can see the properties from Inventor in Vault.
Message 14 of 24
bradeneuropeArthur
Solved then?
Or only for that specific file?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 24
As I stated previously, it is a known issue with the Vault update. (Vault 2021.1 update client I think)
To fix this I removed the update.
The last updates for Inventor and vault have been terrible for bugs!
The time I have lost trying to resolve problems with our Autodesk registered reseller technical department is ridiculous, to find out days later that it is a 'known issue'.
I have removed all updates, but fear the Inventor update has broken the tube and pipe section of our content center.
Fingers crossed for a rectification update . . . . . eventually.
Message 16 of 24
No, not solved. I can see porperties in Vault but the function to change proterties in Vault does still NOT work.
Message 17 of 24
How do i remove the update from vault?
Message 18 of 24
In control panel > Uninstall or Change Program
In the side bar there is a 'view installed updates' option (see attached)
Find the vault update and uninstall.
I'm not sure its the correct method, but worked for this problem for me.
Message 19 of 24
Thanks!
Did this so now i run version 2021.0.1 and I can change the properties in Vault again..
Message 20 of 24
gandhey
Please note the issue is still not fixed and is being worked on.
regards,
Yogeshwar
(Vault team)
