Cannot edit properties in Vault Basic 2021
Message 1 of 24
Hi!
I cannot longer edit properties (ctrl+E) in Vault basic. This used to work fine before. Now i run 2021.1 and i don't really know if the problem started with the latest version...
I can go to Edit properties and then i get the window up. I fill in my changes and click OK. Then i get the report which says: "successfully updated" but then when i close the window nothing has been updated on my file.
Anyone know about this problem?
Replies (23)
Message 21 of 24
C.Geerts6948
is there a change of getting an update concerning this issue??  Because I do not whant to opgrade to a newer version is short therm when 2022 is there. Uninstalling an update can't be the solution to solve a problem.
Or put in the release notes "if you want to solve this problem you get these 2 problems in return"  🙂
Message 22 of 24
bradeneuropeArthur
How has the migration taken place?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 23 of 24
gandhey
Please note this issue has been fixed with Vault 2021.1.2 update.
https://help.autodesk.com/view/VAULT/2021/ENU/?guid=Vault_ReleaseNotes_CLC_updates_fixed_defects_202...
(PDM-30241)
regards,
Yogeshwar
(Vault team)
Message 24 of 24
C.Geerts6948
That did do the trick. My autodesk app "said" my vault was up to date. When I logged in to Autodesk I found the update _2. Installed and it worked
