Batch Plot PDF with Multiple Pages
I have a few problems with the batch plot in Vault 2016.
1. I want to batch plot multiple drawings to pdf's.  Some of these drawings have 2 or three sheets.  Vault will not keep these multi-sheet drawings as a single pdf.  Is there a way that a multi-sheet drawing can be saved as a single pdf, or is this just another huge oversight from Autodesk?  Perhaps there is another way to do a batch plot to pdf????
2. When I plot to pdf, any solid isometric view of the part in the pdf is shown with color stripes as if it were trying to be printed black and white only. This happens if the settings are set to color or black and white.  Any options with this?  This is not a problem with I export to pdf through Inventor, but I would prefer not to have to open every part to export a pdf.
Thanks for the help.
Best Regards,
Pete
cbenner
I've never been able to find a solution to this, but I've never spent a lot of time on it either.  I fear it is a shortcoming.
I've seen this for years, the shaded views, if plotted with the standard PDF settings will do this.  You have to go into the PDF settings and set quality to High to get past this.
Best Regards,
Pete
Good luck!
ihayesjr
Since each sheet is a different print job, it will not automatically append to the same PDF by default.  However if you use a print driver, such as PDF-XChange, you can have the print job append to the existing PDF.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
