File Versions
File Versions
File Versions
I'm trying to view all the file version. I see when you select a file the Preview tab will show the revisions, and it looks like the History tab should show all the versions if you check the "show all versions" box. I've checked the box. The number of version counter says 28, but the message is "There are no items to show in this view."
How might I view all the versions?
Jarrett
Autodesk Vault Professional 2015
upchurt
Hi @Anonymous
I have seen this error before and it is usually related to a corrupt windows user profile. If you login to your computer with a different user account then login to vault do the versions show up correctly?
You can also try removing the Vault's application preference files (this will reset the Vault interface so we recommend you make a backup just in case). These files are stored here on a Windows 7 system:
C:\Users\<username>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2015
Where <username> is your windows login name.
Hopefully this helps as the version history preview is very useful.
-Trent
Trent Upchurch
upchurt
I wanted to follow up on this issue and see if resetting the Vault settings or switching the Windows user account helped.
Let me know if there's anything else we can help with.
-Trent
Trent Upchurch
