- Mute
- Permalink
- Report
Hello Everyone,
I wanna boarden my vault horizon. Therefore, I started with the tutorial under the following link.
https://knowledge.autodesk.com/community/collection/vault-data-standard-tutorial
I think this tutorial was written for Vault 2020. The Sample files are avialible for the releases 2020, 21 and 22.
Currently I work with a Vault Pro 2023. I thought this should not be a to big issues. But immediate in Chapter 01 in Exercise 1 an – for me – insurmountable problem occurred. I was not able to re-route the path for the file.xaml file.
The tutorial indicates that in the “file.xaml” file under the following path
C:\ProgramData\Autodesk\Vault 2023\Extensions\DataStandard\Vault.Custom\Configuration
contain a path to the “file.xml”.
But in my file.xaml there is no path for the “file.xml” file.
I need to describe in more detail. The file.xaml under the Vault 2023 contains no path for the “file.xml” file.
I checked the same file under “C:\ProgramData\Autodesk\Vault 2022\Extensions\DataStandard\Vault\Configuration” and the path is indicated in the file.
Has something changed for the data standard configuration from 2022 to 2023? Where can I configure the path under 2023 so I can create my own File Types in Data Standard.
Is it possible to use the file from 2022 in my 2023 configuration?
Thank you for your help!
