Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Get folder ID from full Vault path
2 REPLIES 2
pball
165 Views, 2 Replies
I'd like to get the folder ID from a full Vault path. I'm currently using FindFolderBySearchConditions and that did not work when I feed it a full path. Below is an example of the folder path I'd like to get the ID for and the current code I'm using.
$/Designs/Reference Parts
    Function Get_Folder_ID(FolderPath As String) As Long()
        Dim mVltCon As VDF.Vault.Currency.Connections.Connection = VB.ConnectionManager.Instance.Connection
        If mVltCon Is Nothing Then Return Nothing
        Dim FolderPropsDef As ACW.PropDef() = mVltCon.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
        Dim ACWNamePropDef As ACW.PropDef = FolderPropsDef.[Single](Function(n) n.SysName = "Name")
        'Set search options, opereator 3 is exact
        Dim NameSearch As New ACW.SrchCond() With {
            .PropDefId = ACWNamePropDef.Id,
            .PropTyp = ACW.PropertySearchType.SingleProperty,
            .SrchOper = 3,
            .SrchRule = ACW.SearchRuleType.Must,
            .SrchTxt = FolderPath
        Dim bookmark As String = String.Empty
        Dim status As ACW.SrchStatus = Nothing
        Dim results As ACW.Folder() = mVltCon.WebServiceManager.DocumentService.FindFoldersBySearchConditions(New ACW.SrchCond() {NameSearch}, Nothing, Nothing, False, bookmark, status)
        Dim id As Long() = {results(0).Id}
        Return id
    End Function
2 REPLIES 2
ericbouwkamp
in reply to: pball
DocumentService contains a FindFoldersByPaths method
pball
in reply to: ericbouwkamp
Thanks for pointing that out. I was able to make that function much smaller and robust with that command.
        Dim results As ACW.Folder() = mVltCon.WebServiceManager.DocumentService.FindFoldersByPaths(New String() {FolderPath})
        Return id
    End Function
