SCENARIO: My plugin gets many PDFs then combines them into a single PDF. The user needs to decide where the PDF will be saved in Vault. Vault Pro 2022
ISSUE: The API below gets the dialog below but this only works for selecting an existing PDF. I also need the user to be able to type a new name. Am I looking in the wrong place or is this not provided in the API?
Autodesk.DataManagement.Client.Framework.Vault.Forms.Library.SelectEntity(connection, settings)
Solved by Nick_Hall. Go to Solution.
Hi Josh
I don't believe that there is an equivalent tool that will allow you to pick a new name
If so, that leaves you two options that I can think of
Hope that helps
Nick
Thanks @Nick_Hall. The first option was my next path as long as I can select a folder OR PDF in the same dialog... hopefully.
