Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
API Save As Dialog
2 REPLIES 2
Josh_Hunt
267 Views, 2 Replies
API Save As Dialog
SCENARIO: My plugin gets many PDFs then combines them into a single PDF. The user needs to decide where the PDF will be saved in Vault.  Vault Pro 2022
ISSUE: The API below gets the dialog below but this only works for selecting an existing PDF. I also need the user to be able to type a new name.  Am I looking in the wrong place or is this not provided in the API?
Autodesk.DataManagement.Client.Framework.Vault.Forms.Library.SelectEntity(connection, settings)
Josh Hunt
Labels (2)
2 REPLIES 2
Nick_Hall
in reply to: Josh_Hunt
Hi Josh
I don't believe that there is an equivalent tool that will allow you to pick a new name
If so, that leaves you two options that I can think of
  • Use that dialog to select the folder to save into, then prompt for the file name
  • Create your own dialog, similar to the one in the SDK Vault Browser Sample
Hope that helps
Nick
Josh_Hunt
Thanks @Nick_Hall.  The first option was my next path as long as I can select a folder OR PDF in the same dialog... hopefully.
Josh Hunt
