Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Upchain PDF translation changes drawing font, blacks-out PNG images in drawing, and loses color
A SOLIDWORKS drawing generated during initial Item creation and subsequent check-ins retains the document font, PNG images, and all colors; however, when an item is released, its PDF translation loses the document font (converting to a new font), PNGs in the drawing convert into a black box, and all colors are lost. This can negatively impact my ability to communicate specifications to my suppliers, to the point that these translations are unusable. This translation automation is one of the main selling points of Upchain, but these formatting problems kill that point. I would like to suggest that in a future update, the PDF translations retain all of the font, image, and also document color formatting from the original SLDDRW file.
3 Comments
DRueda_ARK
For the font i have at the starting the same issue. do this:
- Create new drawing template and use the font: Arial or your preference font. only do some text.
- Check that you show correctly the font.
You need to re-generate from zero the Template of solidworks to clean trash and homogenize the font you use.
lucasGK5RG
I have the same issue and for now there's a workaround for some of those issues:
  1. I suggest using the font "MS Gothic", it keeps the format very closely to what you see in SolidWorks (it can even let you keep fraction formats if you type them in Unicode).
  2. For pictures, you should copy and paste your images with a white background, usually from a JPEG or BMP file, but copy the pixels, not the file in you Windows Explorer.
  3. In regards to the shaded colors in SolidWorks, Autodesk currently uses the DWG file to translate our document to PDF, so it only keeps basic colors like the ones you do in Line formats or Area Fills, if they could map the attributes not from a DWG but from the PDF itself it would be great.
Dear @smcfaddenCYM96 , @lucasGK5RG and @DRueda_ARK ,
We have rolled out improvements to how the population works on the Upchain EAP environment, so can you please go and test if that workflow works for you?
Please note that the population has changed from DWG to PDF, and on EAP, DWGs are no longer populated.
Best regards,
Tom
